Stubborn waterpump fan nut
94turbocrewcab-lb
Mid coast Maine
I dig those grill lights. Do you have any cooling impedance?
TygreII
Rapid City, SD
They came with the truck.
I haven't put him through his paces yet, so I don't know. The lst owner was a Rancher and hauled a horse trailer with it. I did replace the radiater with a 3 core, but that weas because it started to leak.
I have a couple moe things to do, and I'll put my 5th wheel on it and haul it around the Black Hills here in SD. That will give him a good workout.
XOLATEM
Virginia... in the brambles
mandatory for me to work on my engine.
Years ago I cut a 55-gallon drum in two...note I said 'in two' not in half...
I cut it about 70-30 so that I would have a step up for working on a lifted truck...a two-stage step up...it was mainly for working outside or in a driveway...it would have been rough on a shop floor.
The advantage over a shop stool or bench was that it was hard to tip over coming down and had a wide area to land on so it was hard to stumble over backwards...
Only disadvantage I found was finding a place for it that was central to all of the projects...hadda lug it around from spot to spot.
Just my .02
