vandy7.3
I agree with everything Gary said.
That's being said if you still have the factory pump and the wastegate plugged your not likely to see that much boost. At least I don't. WG plugged factory pump turned up about 6 flats or so. My boost tops out around 11-12psi or so. Egts havent gone above 1000 degrees. That's hooked to a 25ft gooseneck with a 3,500lb tractor on the trailer.
But it's just whatever is more convenient for what you're doing.
That's the path I chose because I'm going to stud the heads and put a heavy clutch in and yada yada the list goes on haha.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
