zigg
I've got a turbo off a '94 stock IDI, that I understand is an ATS but says "Ford" on the housing.
This came off an engine that dropped a valve, and ate a piston. My concern is that there may have been bits that found their way out into the exhaust and through the turbo. I didn't see any chunks in the intake, but, I'm worrried about slapping this unit on my new engine.
There WAS a ton of oil in the intake, but it may have come up through the blowby tube, as coolant had gone into the oil and raised the level way up.
The turbo spins more or less freely, and has no grinding or play,the blades look ok, but I can't see up into the exhaust side. it does have oil in the intake side.
My question is, is there any way to test these units, or is there something I can look for to tell if it's ok, without actually tearing the whole thing apart.
Zigg
Zigg
