stick swap questions
benton
Country boy
Bushkill Pa
im picking up a zf in the next week to start my swap. and i was wondering if my tranfer case thats behind my auto with bolt up to the 4x4 zf? also will the drive shafts from the donor truck which is a 88 f350 reg cab and my truck is a 92 reg cab f350 fit my truck?
biggin92
Yeeeee Haaawwww
umatilla fl
Yes your current transfer case will bolt to the ZF, however you will have to shorten the shift linkage bar for the 4x4 shifter,now the drive shaft is a maybe, some of the F-350's used a smaller u-joint in the rear shaft, and as long as the donor is not a c&c the length should be right, The front shaft should bolt right in However.
benton
Country boy
Bushkill Pa
thanks biggin!! im getting a killer deal for the trans, shafts,cross member and alot of other parts! i cant wait to make my truck a 5speed!!!!
Tyler9828
