steering column differences
defecater
Osceola, Iowa
My 92 crew cab dually has a couple of electrical issues that I believe are due to the coulumn wiring (no left rear turn signal, erratic wipers) the key cylinder is pretty sloppy too. Local junkyard has a few C4C trucks of the right era (92-96) but they are all gassers. I believe I read on here somewhere before about the diesel trucks never had the airbags in the column, but other than that, would the gasser columns be compatible with my existing diesel harness plugs??
tknomaj
Anaheim Ca.
all collums are the same from 1992-1997 the only thing is collum shift or floor and those parts can be removed or transfered and the turn signal switch changed in 1997 stalk different and wiring different but yes no difference between gasser and diesel or air bag and non just change slip ring for clock spring
Seven4eight
