Starting problem after fueling
TEXCRAWLER
B.F.E.
I have a 91 7.3 IDI. When I fill the tank w/fuel it will not crank back up. After I try to start it over and over the batteries finally start to die. I let it sit for about 4 hrs. them put some jumper cables on it and it will start. :dunno Any feed back?
Exekiel69
If it only happens when the engine is warm then it could very well be the injection pump. How many miles on the injection pump? Does this happen when cold? Do You use any fuel additive.
MIDNIGHT RIDER
Is it only when you add fuel; or, does it do it any time the engine is warm ??
TEXCRAWLER
B.F.E.
no fuel aditives, only dose it when I fill up and the engine is warn. It was in the back of my mind that it may be the injection pump. high mileage
Exekiel69
Well if it where air then this could happen every time but as You said it happens when the engine (and IP) is warm and this is a common symptom of a slow dieing IP.
IDIBronco86
