f-two-fiddy
Ftwofiddy, refferencing the two pics above where exactly would you grease? I could have sworn the guy at Advance told me they werent a servicable item, although that doesnt mean a whole lot. Mine is basically like the first of the two pics to the left.
I grease the sealed bearings with a hypodermic needle. I have a 8 ga needle that I picked up at walgreens. I fill the syringe with grease, remove the pulley and carefully slide the needle in between the inner seal and the race. When I get the needle in far enough, I inject some grease. Remove the needle and spin the bearing. You might have to repeat a few times. You can tell when there's enough grease in the bearing. It'll smooth out and show a little drag.
