Spray Can Bedliner
dakotajeep
Patrolling
TN/ND
I am thinking of spraying my 87 with bedliner from a can. Used it on a few odds and ends things with good luck. So far I painted the back drop bumper and the grill.
I plan to do some slight body work and then paint it. I plan to use this as my learning curve for doing work on my 2003 F350 (I did spray the hoop steps I have on it but those aren't a big deal).
Just curious if you guys think its even worth the effort. I figure it would cost around $150 for the paint.
Thad
itsacrazyasian
residentcrazyasian
boca raton, fl
don't bother with the spray can. Find a local body shop supplier in the area and buy a kit to spray with a compressor.
dakotajeep
Patrolling
TN/ND
I know but then I have buy the sprayer and compressor or rent. At that point I would have more in tools than the rig is worth. I have already spent more in repairs than what I paid for it. I bought it as a hobby to keep me out of the casinos or bars.
You know what they say about idle hands....
I appreciate the opinion. I may just have to go buy the proper tools. I just move too much to want to make the plunge and buy more stuff.
Thad
itsacrazyasian
residentcrazyasian
boca raton, fl
i should clarify, i myself have used two different brands. One of them i got from my autobody supplier which is Raptor bed liner, which you will need to purchase a spray gun.
SEM products (fairly popular product) makes a bed liner kit that uses the same gun, its a little cheaper and looks to be the same as the UPOL stuff.
Last is the Duplicolor Bed armor kit i used on a friend's jeep for his interior. Again i had to buy a gun to spray this as this comes in larger cans. Seems to be holding up ok, but its inside the truck, not in a bed.
I would use the SEM stuff again. Its not a air cured product like the do it yourself duplicolor stuff. You add the harderner, shake and spray. Its what the bodyshop that i do work for uses.
itsacrazyasian
residentcrazyasian
boca raton, fl
you are going to need to buy a spray gun for this regardless. Rolling a bed doesn't get into all the nooks and crannies effectively.
This is one time where i will say don't cheap out, do it once and do it right. If you have to redo it again because it chips and peels.... Maybe i use my bed harder than you will?
haligen
Conway, SC
I used the duplicolor rattle can bedliner on my s10's lower body panels and fender flares. Held up decent but was a pain to clean, mud seemed to kinda strain it.
jhnlennon
WI
That stuff is useless. I guarantee that over time it will chip and flake off. Read up on it, I wouldnt recommend it.
DesertBen44
Grand Junction, CO
Avoid Herculiner I used that on my 88 Comanche and the sun faded it from black to gray in a few months, also simply throwing a shovel in the bed would scrape up a huge chunk of liner.
I rolled it on though, 2 coats I think and chemically cleaned the surface first with MEK.
Diesel_brad
Dunce
gilbert pa
Thad
You are going to bedline the OUTSIDE of the truck?
DONT.
Just buy a decent single stage enamel from Napa. They have a selection of premixed colors for about $50-60 a gallon or less. It will look way better and you will be able to refine your body work skills
DeepRoots
Tug Engineer
Douglas, Georgia
and do me and the rest of the world a favor, pull the freakin bed bolts before you use bedliner....
its real annoying when people use that crap over everything. There is no reason for it.
thanks!
Vincent
