Popeye2347
On my early 1994 F250, 7.3NA, auto, the speedometer needle is steady up to 65MPH, but at or above 70MPH it will bounce. This is only an irritation except that it also causes the cruise to 'hunt', and no doubt hurt the fuel mileage.
I picked up some white lithum to lube the speedo cable, but to my surprise there is no cable to lube!! So, where is the electronic sender/pickup unit, and
is there anyway of telling beforehand if the problem is the sender or the speedometer head without blindly replacing parts and see what fixes it?
On a side note, I had the instrument cover off this last weekend to repair [hot glue] the tank selector switch that 'fell' into the dash. On the speedometer part is a bright orange label cautioning anyone not to turn the speedometer module 'upside down', and to call Ford at 1-800-***-xxxx. What is this all about? I cannot fathom anything that would be harmed, but then this 'modern' stuff is full of surprises!
