Diesel Max
93 F-250 4X4 - 7.3
Ok here goes................. 93 F250 4X4 -- ABS in rear only. I repaced my rear wheel axle seals and rear brake shoes this weekend. I also vacuum bled all 4 wheels to flush the system because the fluid was about the color of root beer (this is where I think the problem comes in). After completeing all the work, I started the truck and had the brake and ABS light lite up on the dashboard. When pushing the pedal with steady pressure, it slowly sinks to the floor. If I pump the pedal, the pedal pumps up and gets firm but then applying steady pressure, it again slowly sinks to the floor. The brakes do work on the truck and stop it quite well. It's just the sinking pedal that I cannot get a grasp on. Below is what I have done to this point.
Bled the master cylinder, rabs valve and all 4 wheels numerous times. I have bled eveything with the vehicle off as well as running. (have bled over a quart of brake fluid through the system at this point) I use a clear hose on the bleeder valve and see no air bubbles commng out any where.
Rear brake shoes are adjusted correctly after replacement.
I have vacuum bleed as well as pedal bleed.
I have used master cylinder plugs to plug the two lines (holes) comming out of the master cylinder, to verify it the master is not bad. When master is plugged, pedal holds fine and frim and does not sink.
I have clamped off the rear brake lines, check the pedal with only the front lines normal and the pedal still sinks.
When I leave the rear rubber brake hose unclamped and clamp the left front caliper brake hose, the pedal firms up and sinks very, very slow. When I clamp both the right and left front rubber caliper hoses, the pedal is firm and acts normal.
So............. logically thinking, there must be air in the front calipers right ???? Well, I have bled atleast 1/2 quart of brake fluid through the front calipers and I see no air comming out.
As a side note, after I bled the entire system, the brake light and ABS light are now out.
There are absolutely no leaks of any kind any where and the fluid in the master resivor never drops.
I am at a complete loss here............ Has anyone ever experieced anything like this and can anyone give me any ideas of what to look for or what the problem could be ??? No work was performed on the front brakes with the exception of bleeding them.
Thanks for any help................
