SMF flywheel that uses stock DMF pressure plate
91crew
San Luis Obispo, CA
Do you guys know if someone sells a single mass flywheel that accepts the stock DMF 6 bolt pressure plate and 11" clutch? I just bought a SMF to replace my Lucky modded flywheel, but its for a larger clutch with an 8 bolt pressure plate.
Cheaper Jeeper
Kent, WA
I don't think you're going to find what you're looking for. The DMF is about a half inch thicker than the SMF and the pressure plate is a half inch shallower to make up the difference so they can both use the same throw-out bearing, fork, and slave cylinder.
For what you paid for that replacement flywheel you could buy a refurbed stock SMF from Napa and an 11" SMF pressure plate from Autozone...
ntjapkes
