Sloppy BW T19 shifter
Petri317
Napa, CA
My shifter has a heck of a lot of play in it, and at times is very sloppy (read:a pain in the ass-cuss ) to shift. I know it is not the transmission itself, as it was recently rebuilt. Is there a shifter rebuild kit (IE:pins, or bushings, or something in the shifter to replace)?
Thanks in advance,
Peter A.
OkieGringo
OkieGringo aka Baja
Claremore, Oklahoma
Put trans in neutral and unscrew the cap that holds the lever in. Then you should be able to see if the pin or the hole is worn out. Sometimes the vee/U in the case is also worn. Try using MarineTex epoxy or liquid steel to rebuild the U. This is what happened to the T-18 in my Jeep CJ-5. Good luck, OkieGringo
Petri317
Napa, CA
Thanks Okie. I'll pull the cap and check it out. I'm still hoping there is a kit that has the necessary hardware to rebuild the shifter. I guess it's off to a transmission shop. If all else fails, I suppose I could find a junkyard shifter. Even it would have less play in it than my current unit!!!
NO_SPRK
User & Abuser
Santa Rosa, Ca
found this video online and thought i would share it for repairing sloppy 4spd shifters
not mine.. not a guaranteed fix. not a actual diagnosis of problem.
http://youtu.be/HXSdniEENpc
Thanks in advance,
Peter A.
ntjapkes
