Showing off the truck
Sidewinded_idi
Yucaipa ca
My srt is 2.5 and the turbo is almost three times that size! But I understand what your saying. I'm sure hey want zero lag as well so they spec it small for good drive ability. Just a random pic of the Honda Odyssey I purchased barely fitting the trailer( truck towed it no problem!)
And if anyone's into 4 cal this is my daily driver caliber srt, one of only 5400 made (it's nothing like the neons doesn't share any part with them) I have full exhaust, kn drop in and dyno tuned with a ms1k computer. On 20 psi it made 350 hp to the wheels and 400 lb-ft torque. Unfortunately that was with some 100 octane so we backed the timing off and left it with 360lb ft torque and around 340hp so I can run pump gas reliably
Sidewinded_idi
Yucaipa ca
Iirc, the only one that shares parts with the srt4 neon is the pt cruiser.
Correct, the caliber srt like mine is basically the same car as the lancer evolution, same heads block, suspension, just a stroker crank 2.5 compared to the eco 2.0
Sidewinded_idi
Yucaipa ca
Changed up my coolant lines abbot. I had the heater disconnected but now with the propane conversion it gets so cold I decided to hook it back up. I added a tee in the in out line but most the flow will go straight through the heater core and out to the filter. If I decide to close off the heater core with the ball valve I put a swim gate right on the heater outlet so it'll keep and flow from the other side entering so it'll isolate the core completely with only one valve
RangerDanger
