slim072590
I have read on here and some other site a a time or two.. about when you replace injectors sometimes you have to shim, or move them back up to adjust the fuel spray, i think...
and searching has taken me no where on this... does it always have to be done? is it just for extreme perfection?
im starting with injectors because when i read my temps coming out of my exhaust manifold the passenger side cylinder closest to the radiator was running about 30-50 deg colder then the rest, and it has a slight knocking all the way through the RPM range.. and lots of white smoke
the job looks easy, just pull lines, pull injectors, use oil to set the O-rings, top first then bottom, then reconnect and fire up.. unless im missing something
if you have advice, that would be awesome.. or if you have a link to these questions already answered, again, awesome
Thanks,
Nick
Thanks,
Nick
