gatorman21218
I got mine from ford a few years ago for 90 bucks. think IH has em cheaper.
would an IH semi truck place have parts for our trucks?
How would you suggest to clean it then?
build one of these and carry it with you next time you go to the duck blind.
The CDR does not regulate any kind of flow.
The only reason it's there is to stop a possible run away engine in case the engine starts injesting it's own oil.
Just try and get the spring to compress. Hook Your compressor up to it, and blow air thru it, It takes a hella flow to over power the spring to even start to close the diaphram. More flow than it will ever see on the engine.
