Sag Pump Conversion Problem
crash-harris
Breaker! Breaker!
Chillicothe, OH
I finally got around to installing my E350 7.3L power steering pump bracket to use the GM ham can and a pump from a '93 E250 with a 4.9L (AZ/Endurance part# 7075). It turns out, the diameter of the shaft is larger than my dual v-belt pulley. I have a pump from a '90 E350 with an IDI arriving today (AZ/Endurance part# 7085). I'm just curious if I'll run into the same problem here, or if I need to just get a different pulley. None of my searches return any info or availability on a PS pump pulley for a v-belt IDI with a sag pump.
So to anyone that's done the swap, what pulley did you use?
crash-harris
Breaker! Breaker!
Chillicothe, OH
Looks like there's no difference between the 2 pumps. I ordered a 300-121 pulley, so I'll be waiting another day for that.
crash-harris
Breaker! Breaker!
Chillicothe, OH
I've installed, removed and installed pulleys and pumps so many times that I'm very close to lighting it on fire...
The 300-121 for a GMC truck with a 350 can only use the outer of the 2 grooves. The single groove pulley that was sent to me with the bracket is so bent that it looks like fan.
So does anyone have a part number for the van v-belt pulley? I'd rather have a dual belt pulley, but I'll take a single belt pulley at this point...
chillman88
Central NY
Are you on FTE at all? They have a guy on there that has all the old parts books and usually can dig up a number.
crash-harris
Breaker! Breaker!
Chillicothe, OH
I am not. Honestly, I only really visit here anymore as far as forums go.
I guess I'm going to attempt to cross reference the Ford part number on the bent pulley when I take it back off.
m2rtin
