The one with the plastic is wrong. That's some sort of an oil pressure switch. You need a pressure sender.
Jonathan my truck has bb coded injectors and the steel lines are all rusty and pitted. Not leaking but i would imagine they are on their way.Most of us like bb code injectors. What wrong with the steel fuel lines. I would say in that heavy truck a pyrometer is mandatory. Pm type4 he sells injectors and return line kits.
You must be registered for see images attachYes they are real gauges.
As far as using sealant on the freeze plugs? I did use a reputable shop. They actually mostly built race motors. They seemed knowledgeable and they are located in a small town off the beaten path. I personally know they have been in the same location in business for 10+ years. I trust that that to survive where they are they have people that come to them because they are good. But guess I can double check their work. I do have to pull a freeze plug to install my block warmer. While we are talking about sealant an ol' diesel guy told me NEVER use silicone on a diesel, something about breaking free and clogging up the oil squirts. So I am using this for the valley pan and just about everything else.You must be registered for see images attachAny experience with this stuff?
