seawalkersee
It needs a turbo...
I have been fighting this thing for a long time and I have gotten to the point where I am stumpped.
Yesterday I finished REpopping all of the injectors and wound up replacing 3 of the ones that were less than 1k old. They were an e-bay set of BBs that I pop tested and set in Dec (I think) after getting the engine back together. Well, there are apparently at least two different styles of tips and bodies. They have a different thread pitch and different nozzle end, but back to the thread. I had some that were just ******* a stream and leaking. I swapped them out with the set that I had when I got this thing in 08. Got them all within 100 psi of them and put them in.
It ROARED to life without a lot of cranking (this is two days with the fuel system sitting open). Ran it long enough to get the air out and heat up a little and shut it off. If there is any type of heat still in the engine (warm to the touch or even sitting for 4ish hours or less) it will start with no problems.
It is in my garage which is about 60-70ish degrees. I went down there this morning and hit the key....it cranked and cranked and cranked. I stopped after about 15 sec. or so and said screw it.
There are no external leaks on this and I thoght about what gary said by putting a clear line kit on it to see if there is air getting into the system.
First question:
1)Is there a certain way the line kit has to be attached? Mine goes down the pass side from the filter head from front to rear and then over to the return line from the pump, then back to the tank. The driver's side goes back to front with only the rear injector going to the return line. The front cap is a dead head. I will try to do a diagram...
o------l---o
l l l
o l o
l l l
o l o
l l l< Had to crack this line loose
o 0/ o
l
0 ^
IP
Filter
So, after I get it running, there is NO fuel coming from the front two injectors on the driver's side. I took one line loose to allow all of the air to get out and put the fluid to the front injector. I let it run for a while and it seemed almost immediately that it ran even smoother as soon as the return line was full, but I am almost sure that is a coincidence. But if it is not, than I am almost sure the lines are plummed worng.
Second Question)
If I am not getting fuel to the dead head injector but it is filling the two previous lines, is there a pump problem that it is not pushing enough fuel?
SWS
First question:
o------l---o
l l l
o l o
l l l
o l o
o 0/ o
l
0 ^
IP
Filter
Second Question)
SWS
