well, if you are not moving your current hitch, i don't think you can use the superduty springs, reason being, since the SD springs are longer. If you put the RSK in the same spot as OEM at the front of the frame, you would have to move the rear hanger farther back, and that would not put the axle in the center of the springs. So if that theory is correct, it seems as though there is minimal gain in the ride of an RSK while using obs springs, therefor in my mind making the RSK a waste. With all that i honestly think you would be better off keeping the spring set-up you have now and taking that money you would spend on SD springs and RSK, and invest in some GOOD shocks, either Bilstien or Icon shocks. i have heard great things about bilstein(have them on my truck) and have heard even better things about Icon shocks.
the three RSk makers that i know of are....
PMF, SKY, ORU.
you CAN use all three of those with obs f-350 springs.
