code 35 is a 4.10 axle. Your tag confirms that also. It never fails, the factory always punched out the first number for the bolt hole. Yours has a "10" because they punched out the "4". If you had a 3.55 your tag would read "55". If you had a limited slip rear, the tag would read "10L" or a 3.55 limited slip would read "55L".
