big van
Nobody Special
I have a 91-7.3 N/A about 120K miles in my van and I'm not looking to turbo for a while unless some $$ drops from the sky. Returns were leaking and everything looks original gray like it's never been touched. So I took off the IP, Db2831 4817 is the # on it. Was going to replace with the same # rebuilt. Injectors are code D. I know some guys have replaced them with different codes. Is it a good idea to use another code & why. What code is best to use. I was also going to get rebuilt injectors. They charge to have them tested but I hear it's a good idea to test them even though they're rebuilt. I was going to get the parts from Fuel Injection in Fogelsville,PA. They rebuild everything themselves & have been for at least 30 yrs. Any one ever use them?
Also my pulse timing adapter was on #6 cyl. and not #1 cyl. Any ideas on this? It should be on #1 so I'm going to put it there when I reassemble. I just hope return lines work & #1 isn't long & #6 short. My air intake runs really close over the top of # 1.
Any one know of a good shop in SE PA to dynamic time when I'm done? Thanks for the input from everyone.
Matt
Matt
