RED POWER
LOGANSTANFORTH
IH tractor power increases.
You should have a American Bosch M100 Pump on the DT436. Remove the 4 bolt cover on top and turn the screw in 1 to 1/2 revolution.
966's will find an increase with a turbo from a 10/14/15 66 series tractors, the only thing is you need a donor tractor for turbo, lines, fittings, manifold, and the fuel tank and brackets. this is all worth about 45 horsepower. the fuel tanks are different, the turbo models have a notched tank so the exhaust stack will miss. you will also need to either cut a hole in the hood or find another 66 turbo series hood to fit it. Becareful on a turbo on a D436 I don't think they had piston oil coolers on them like the DT414/DT436/DT466. I picked that little tidbit of information from another site, Logan.
***MIND YOU THAT THOSE TRACTOR REAR ENDS WE'RE MEANT TO TAKE ALOT OF HORSEPOWER SO DONT GET STUPID WITH IT***
Ill have some stuff for you deere guys when i get time.
Interesting post. Was this a reply to somebody else, or are you just throwing that info out here for the general good?
JU57US
