I just got my rebuilt sleeved 93 7.3 turbo engine put in and running in my truck. It has massive blow by, and has a shake at idle. The exhaust runs clean with no blue or white smoke. I have a road draft tube on it and the vapor is bad enough to see out the window at idle. Is it normal to have a lot of blow by on an engine with 80 km's on it? Would a bad injector cause the shake but produce no smoke? I also have a 6.9 solid flywheel on it, are these flywheels balanced to the engine or are they neutral balanced? The flywheel ran smooth on my n/a 7.3, but I'm wondering if the added mass of the turbo pins/rods with the 6.9 flywheel is putting it out of balance. Thanks.
