Rebuild kit
Popspuller6.9
Prosser, Wa.
I am rebuilding my 1984 6.9:sly who makes a good master rebuild kit for this motor. my plans are balance low end, ceramic coating pistons, R&D cam, R&D turbo cal pump, and R&D high pop pressure injectors. your thoughts or suggestions PLEASE! :thumbsup:
Sounds like you've done some good research and have a good plan going. By master rebuild you want new pistons, con rods, crank, and all gaskets, seals, and bearings correct?
88 Ford
San Diego, CA
To be honest from what I have seen, most guys just source parts all separate. It will usually end up being slightly more pricey but you will get better quality that way IMO. Some of the other guys will probably chime in on this but that is what seems to be the popular way to do it...
