7.3 powerstrok
from a cold start outside temp 35 degrees.....after say a 20 mile drive speed 40-50 mph ,whats the temp on youre truck around the pinion housing ,,,cold warm/very warm /hot/??
From what I've seen 250* seems to be a typical upper limit for most lube oils, so anything under 200-225 should be fine.
Hard to say how hot it actually was, I'd think ~150* from that type of drive and weather wouldn't be abnormal, but 180-200 would.
That being said, if there's any question make sure you have the correct fluid/additives. I think some gear oils don't need the friction modifier additive but I'm not sure. Someone who knows more than I can chime in here.
I really have never given this much thought. Now I feel I should be checking it. I do have a lot of back lash in the gears so maybe its time to replace them. Way too many miles of heavy towing on them with no upkeep at all.. Same oil in there probably 14 years now.. I'll bet it smells really horrible too.
Yes Al... This is one location that I really never look closely at. I do check the brakes and the universal joint every time I change the engine oil. Or at least I look over the joints and the brakes when I lube the universal back there. Just don't change the fluid back there but do look it over for leaks... Never see any. As I posted.. I think it time to change the gears and the oil back there. I'm still on the fence about 4.11 or 3.73...
