Yes the adjuster can be reinstalled backwards or even on the wrong side of the truck. Mine works great... But this is after I installed the hydroboost along with the peddle and 1 5/16 master cylinder. I don't do "things" half assed. Most doing this conversion wont use the proper peddle. Anyway the adjusters really don't work like they were designed to. Adjusting them manually is about the easiest way to make sure you don't ruin the front brakes because the rears are way out of adjustment and the fronts are doing all the braking.
