LCAM-01XA
So I'm needing new U-bolts for the Sterling in my 1-ton, and I get a hold of big spring shop I found highly recommended online, they say my truck calls for bolts with 3-5/8" tube diameter. I go measure my axle and it's 3-1/2" tube diameter. Spring shop swears their u-bolts will work fine, as that's all they install on Fords with big axles. We're talking 5/8" grade-8 bolts here that get torqued to 170lb-ft and then provide clamping force of over 16,000 lbs. So maybe I'm being paranoid, and the 3-5/8" bolts will work fine on the 3-1/2" axle.... What says the collective?
