Rear 4 ways come on with turn signals
Thewhiterustbuckt
North carolina
Anyone ever had their rear 4 ways come on when hitting the left or right turn signals? My 88 with tilt wheel just started this. Never seen this happen before.
There are no "rear 4 ways". When the emergency flasher or 4 ways are activated, they use the same wiring and the same bulbs as the turn signals.
I think what you are saying is when you activate the left or right turn, both are blinking correct? The first place to look is any trailer wiring back there. Make sure it's not shorting any wires together, sounds like the left and right brake/turn wires are touching each other somewhere.
Thewhiterustbuckt
North carolina
Yes no matter lights are on or off. I stoped for a couple days then started back. Now also the turn signal will stop flashing when applying the brake.
ps444mike
Southern Calif
check for shorts.. but also look at the blubs.. I had one that the filament came apart an shorted inside the blub blinkers problems brake lights turned on blinkers etc.
