Real Easy Injection Pump removel Trick
Devon Harley
San Diego
I install an pull the ip everytime as a whole. Never thought it should ve done other way or that it was. my gf calls em the spider web thingy haha.
gandalf
Senior Member
CA &/or Maine
Gary, you hit the wrong video. I just watched your timing meter.
You've made a number of these quick 'hot to' video for us all. Could you maybe post a list of links for them all? You might even convince the powers-that-be to make it a sticky.;Sweet
Check all they videos you posted today. I've seen at least 2 of this same one so far.:eek:
vegas39
las vegas, nv
I've never had a problem removing the pump with the lines on either, must be luck.
I do remove the top pump mounting stud as I'm sliding the pump back, seems to give it that needed clearence.
