Raptor fuel pump for WMO?
itsacrazyasian
residentcrazyasian
boca raton, fl
Anyone using the Raptor pump? The Carter mechanical pump kicked the bucket on me, so i flipped over to the Holley Blue electric which does not like WMO at all.
I've installed Raptors on WVO conversions i've done at the shop. I figured if they can pump wvo reliably, wmo can't be too much harder on them.
But before i go and drop the big $$$ on one.... Any users?
Fordsandguns
Fords Rule
Eastland Tx
Why not try the turbowerx pump that wmoguy is using? I think the only issue he had was regulating the pressure low enough for the ip. It was listed at 250 on their site.
You posted in his thread but I thought maybe you might not have remembered.
I can't help with the raptor as I haven't ever had one. Hell, I'm just running a mechanical on mine. Anyway the turbowerx looks interesting.
http://www.oilburners.net/forums/sh...-Holy-power-gain-Batman!!&highlight=turbowerx
itsacrazyasian
residentcrazyasian
boca raton, fl
I have one of their pumps from when i did a remote mount turbo on my V6 F150. They specifically say not for use as a fuel pump. I had their "premium" version too.
CaptTom
ca
Could the disclaimer be because 1) the one which makes no sense to me- it can't handle diesel or not flam-proof for gasoline, 2) my biggest suspicion why- a lot of people don't know what a pressure regulator is and they don't want the liability for wrecking IP's or flooding engines/ blowing out carbs etc?
I wonder what other reasons there could be?
Their site says this:
Alternative applications
The pump can be used as a transmission fluid pump, to pump system coolant, and as a
pressure pump for water/alcohol injection. It can handle diesel fuel as well. All the same
conditions/suggestions above still apply.
for this pump: http://turbowerx.com/Scavenge_Pumps/Base-Model_Pump_Manual/files/Base-Model Pump_Manual.pdf
Since it's used specifically for oil, and can take diesel per their instruction, a WMO set up seems perfect to me. The only dilemma I see is, it only primes to 5 feet (suction side), it is designed as a pusher so relocating to the rail may be necessary.
Maybe the one you have/installed was/is different?
$150-$200 saving will buy some other good stuff too, like the regulator and line.
itsacrazyasian
residentcrazyasian
boca raton, fl
My pump is on the rail anyway. I've used the Raptors before. I'm gonna get another one for the General. Let you know how it all works out.
wmoguy
Colorado
The base model pump (turbowerx) has worked fine for me thus far w/ roughly 7k miles on it. The reason I was told it's not fuel rated is because of liability purposes. I have my pump mounted on the passenger side fender and it draws fuel just fine from my transfer tank (only fuel tank) which is in the bed of my pickup. W/ the pressure regulator on there, enlarged fuel line and return line, it has no issue purring along at the 7psi range even w/ heavy WMO blends. The enlarged return line is a must though, this pump moves too much fuel to try and plumb into the puny lil stock return line
idiabuse
Princeton Fl
The whole fuel system needs to be modified, putting a awesome pump on OEM lines is like bringing a quart of water on a 20 mile mountain hike.
My holley blue pumps WMO just fine @ 1 psi 2 psi 3 psi up to 14 psi
I have it plumbed in with a return line system with dual feeds dual returns and a bypass regulator the has a boost port.
So at idle the pump puts out 3 psi and at 10lbs boost 13 psi total
Javier
