Radio and other Wire colors
Status
Not open for further replies.
typ4
Newberg,OR
found this, might be helpful. May need to go in tech section.
Was listed for an 85 F-250
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery LIGHT GREEN (+) RADIO HARNESS
Accesory YELLOW/BLACK (+) RADIO HARNESS
Illumination BLUE/BROWN (+) RADIO HARNESS
Power Antenna N/A
LF Speaker (+) GREEN
LF Speaker (-) BLACK/WHITE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/WHITE
Amp Location NOT LIKELY
Radio Security NO
Security
Battery YELLOW (+) IGNITION SWITCH HARNESS
Ignition 1 RED/LIGHT GREEN (+) IGNITION SWITCH HARNESS
Starter 1 RED/LIGHT BLUE (+) IGNITION SWITCH HARNESS
All Door Trigger BLACK/LIGHT BLUE (+) AT LIGHT SWITCH
Trunk Trigger N/A
Hood Trigger N/A
Alarm Disarm N/A
Parking Lights BROWN (+) AT LIGHT SWITCH
Convenience
Headlights-Lo RED/YELLOW (+) AT LIGHT SWITCH
Trnk Release N/A
Remote Start
Accessory 1 BLACK/GREEN (+) IGNITION SWITCH HARNESS
Anti-Theft Descript NONE
Key Sense BLACK/PINK (-) STEERING COLUMN HARNESS
Neutral Safety NOT GROUNDING
Tachometer DARK GREEN/YELLOW (-) AT COIL
Speed Sense GRAY/BLACK 8000 (AC) WIRE HARNESS FROM TRANSMISSION
Brake Lights GREEN (+) AT BRAKE SWITCH
Reverse Lights BLACK/PINK (+) GEAR SELECT SWITCH ON TRANSMISSION
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock PINK/GREEN (REV) REVERSE POLARITY
PowerLock PINK/LIGHT GREEN (REV) DRIVER'S KICK PANEL
LF Window Up LF:RED
RF Window Up RF:RED/BLACK
LR Window Up LF:YELLOW
RR Window Up RF:YELLOW/BLACK
there you go.
_________
Thanks Russ. Worthy of future reference for sure. :thumbsup:
Status
Cv axle
