GaPchNCrm
My radiator has a pretty bad leak across the front at the top at the seam. When you squeeze the hose you can see water shooting out of about a 3 inch area. I've gotten conflicting answers on if it can be repaired or not ( some said yes, weld/ solder it, others said no its an alloy and you can't do it.) I'm thinking just put a new one in and be done with it... where is the best place to order one online?
