NJGearhead666
ok ive done a ton of reading up on this site about the infamous brake peddle fade. i quick backround on my truck. it has been parked for 2 years with a broke brake line. The brake system was completly dry and i had to replace both calipers and both wheel cyl. and a bunch of brake lines and the master and still i have the brake peddle that you can pump up and then it bleeds down to the floor.
now im thinking that its the RABS valve from all the reading ive done on here so here are my questions.
Can a RABS valve go bad from sitting dry for all that time? and how do you check to see if the valve is bad?
