dieselgiant
Dieselgiant
Just finished a test drive after doing what geonc did here http://www.oilburners.net/forums/showthread.php?t=17484. I used the same fans and motors. My question is while I'm driving back roads just going 45-50 temp stays at 192-3, which is higher than the mech fan with no shroud. Then on the freeway doing 65-70mph to goes up about 197-203. Are the fans restricting air passage at speed or what? When siting still with A/C on Max it goes below 190 even saw 185 siting at a red light. Sounds like they are restricting air flow at speed but I'm not shur. Its not really that hot but its hotter than normal.
I also noticed it was a bit more responsive without the mech fan on it
