Questions about mineral brake fluid.
Columbus, Georgia
I have some mineral brake fluid left over from a truck I had that had wet brakes. What would happen if I used this fluid on my conventional brake systems? Could it be mixed with the DOT or silicone stuff I have? What makes it different from other brake fluids? If I cannot use it with what I have, what else is it good for?
sassyrel
iowa
as the original burner,,of wmo,,ill burn about anything..but for some reason,,brake fluid,,just doesnt sound good to me:dunno:dunno,,reason,,if you put any oil of any type,,in a brake system,,it will turn the seals to mush..brake fluid,,where oil should be,,will do the same thing,,rubber compositions are different...maybe it be ok......i can tell you this,,it peels paint good...........................
Columbus, Georgia
I was thinking about using it with my used engine oil. But I agree, some brake fluids will do a lot of damage. This stuff is different though. I just do not know how much different.
sassyrel
iowa
got a chemist friend???
HarleyCummins
