pyro temp's
cowfarmer16
locust nc
i put guages in my truck on may 23, then the next day left out for the ranch in way west texas . the boost hit about 32 psi, trans temp never got above 170 degrees (that was in nashville tenn in HEAVY traffic, pyro stayed around 550-600 degrees. That was all with a 46 foot eby cattle trailer. My question is i straight piped the truck and now the pyro stays about 600 degrees, when you get on it it goes up fast but never above 750-800 then gors down very fast and back to 600. with or w/o the trailer it dose this is it normal or ok ?
FordGuy100
Silverton, OR
First off, I'm just going to go out on a limb here and say you have a PSD. For a 7.3 that would mean your running a tuner to get that boost, and might be able to hit that stock with a 6.0 PSD.
Anyways, where is the thermocoupler located? Downpipe?
Whoa, I'm in the 6.0 forum, sorry :D. Still, where is the thermocoupler located? If its in the exhaust manifold, or at least pre turbo, that sounds really cool, almost to cool to be honest. If its after the turbo, that just might be normal.
Mike
Stroker
Cora
Your pyro temps sound low but.... where is the thermocouple located? If it is post turbo it could be as much as 400 degrees off which would make your 800 actually closer to 1200.
cowfarmer16
locust nc
the thermocoupler is directly behind the turbo by the bend in the downpipe. the truck is a 2004 6.0 4x4,crewcab,9 foot flatbed.
FordGuy100
Silverton, OR
Then it might be alright. Like Mike said, you can see up to a 400* drop, so 800* is like 1200* at the manifold. I would limit it to 800* though if I were you, just to be on the safe side. That is, unless the truck is stock, then you should be all good (up to its GVCW).
What kind of gauges did you install?
cowfarmer16
locust nc
The truck is stock we didn't even stop to check the weight. we run our thucks hard and expect alot out of them. I bought the truck with 15,000 miles on it and this trip will bring it to 250,000 miles on the odometer. Reason why i am asking is i gotta go to mclead, Montana leaving at 2:30 in the morning.
FordGuy100
Silverton, OR
I would say you should be good to go then if its stock ;Sweet. Just dont go WOT for mintues on end going up long steep grades LOL
tgatch
Yeah, if it's made it to 250k, you've got yerself one of the good sickohs.
Maybe you can tell us all about the monster power put out by your factory rated 200HP and 300lbs-ft 351 gasser sometime. :rolleyes:
olsen726
