puting strait axle in a 94 f250
lynch
little stinker
Harrisburg MO
the ifs (twin I beam)front end you have now will not be a problem adding even 400 lbs of engine unless you re running big tires or want to lift the truck or converting to 4x4...i would leave it alone
yes I would like to lift it 2.5in and run 33's on it
Diesel_brad
Dunce
gilbert pa
Well I can make as much horse power out of that engine as the old cummins dodge used if not more I seen it done. The best part is the cummins guys only get 20 maybe a bit more in mpg I would be getin close to 40 lol.
ha ha you are delusional:rotflmao:rotflmao:rotflmao 40mpg and 400HP:rotflmao:rotflmao
