Project Mosquito Control...
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Had a friend that works t the International dealer bring over some special tools to measure the liner protrusion, the cylinder to wall gap and to yank the liners!
HOLY CONNECTING ROD!
Time to order a gasket kit!!!
ocnorb
IDIT
Wasatch Front
Jon, you really should get a piston and rod from a Cummins and an IDI or Stroke and do a comparo picture while you have those out!!
Hard to do justice to just how massive they are. When I pulled the oilpan on mine I was amazed.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Found a couple scored main bearings. the crank is spotless though, so i'll just get a bearing kit too.
So new pistons and liners or did everything check alright?
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Everything appears within spec. I took a liner and piston to a friends shop, he said by time I clean it up I'd be better off with a liner and ring kit. So I'm waiting on prices for a ring, bearing, and gasket kit.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
TRUCK PARTS!
SO SHINY!
Could ****** my jugs for hours =)
Front bolted in, waiting on u joints.
Got the rear u bolts, have to whip up some spring mounts and bolt it in!
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Almost a roller, as soon as I dig up the pass side caliper bracket!
Looks good man. I am hoping to have mine rolling real soon again too. That's always an exciting time. ;Sweet
PS, nice jugs. :rotflmao
6.9poweredscout
Bleeds IH red...
Northeastern Pa
pulled the crank to get the block cleaned!
All the grease....and most of the paint stripped. spent 3 hours in the hot tank while I cleaned a 5 gallon bucket (literally) full of v12 cummins head bolts on the wire wheel.
half hour with the wire wheel.....
Time for some test fitting liners!
Threw on the pistons.
Set the crank in, need some plasti gauge to measure the crank. and have to find the specs on the clearances.
Some sun bathing. been a while!
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Crank is torqued, pistons are ready to go, liners are measured and dropped in! gotta get it back on the stand tomorrow.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Pistons in and dropped off the frame!
olsen726
