Project Mosquito Control...
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Got the rebuilt head back from my friend's shop.
Trying a Blazer 32 gallon fuel tank. i'd prefer to go plastic, but I got a steal on this one with a lifetime warrenty!
BLASTED!
FITS LIKE IT BELONGS!
Go time!
Brandon throwing down the primer.
Looks sooooo amazing!
More to come!
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Baby steps, been helping my friends a lot lately, and got a few things done on my dually. but here's the progress on the travelette!
all the brackets installed.
Front tin cover on, cam in, lifters in, head on. Waiting for new idler gear bearings.
Some big bearings for just a idler.... gotta love IH!
laserjock
Almost there...
What did you torque your bracket bolts to? I started putting mine on last night and I torqued them to 45 ft-lbs because I thought I read that on here but that just doesn't seem like very much on something fairly critical like a spring hanger. Thinking I will go tighten them up a bit more. They are about 7/16 so can't go crazy but, it seems like that's just not enough. Nuts were anti-rotation though from Doorman so that was nice.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Slow progress, was prepping the dually and a friends scout to go wheeling in Jersey! got a few things together.
Smashed out the dent, little mud to smooth it out!
Got the pump back, again. Done right and tuned for exactly what I want, not just "maxed out"
Don't mind the random fittings, just keeping the paint out!
6.9poweredscout
Bleeds IH red...
Northeastern Pa
here we go!!
modified the frame mounts to accept the factory DT mounts:
Have fun cleaning the sticky off your keyboards!
LCAM-01XA
my very own hell
About time you put that engine in! LOL Is that IP supported at the tail end somehow, or does it have just the bolts that hold it to the timing cover?
And I just thought of something, with all that weight on the front axle, did you ever consider trussing it? Maybe not on the top cause of oil pan clearance, but the bottom? Not gonna lose much of ground clearance, and will help strengthen the whole housing quite a bit.
ocnorb
IDIT
Wasatch Front
Super looking Jon!!
I found a Travelette and I'm trying to figure out how to approach 'she that must approve all cash transactions' about it.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Gm sending unit reads 0-90 ohms, IH reads 73-10 iirc. well I had to do something to make the gauge work!
checking the sweep, little bending and it's close enough to work.
There you have it, hybrid sensor!
also got the installer tool from Gene at IH to get the seal in!
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Made some 9/16" rear spring plates
Remade the engine mounts to work with the factory isolators. The tapered piece is from a Farmall tractor....
Going through the 205:
This looked severely damaged to me, but nothing rides on it, just a sleeve over it, pulled apart a dodge case I had and it's the same. weird how they left it that rough....
Top IH 205, lower Dodge 205....
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Reassembly!
Time for a beer and to relax.
