Project Mosquito Control...
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Found the correct clutch fork!!
Made a grease whip hose. For the throwout bearing...
Got back the powder coated turbo parts.
Used Eastwood rust encapsulator on the hard to reach and usually rust probe areas. Then onto the black on the box and cab!!
Should get some Orange on this week, then get the box and cab back on the frame!
laserjock
Almost there...
That is ****. Wish mine were that far along. So you used the rust encapsulator and not the internal frame coating stuff or you used both?
BrandonMag
Dana 50 rebuilder
Oregon east
Looking really good, Jon. ;Sweet
I like the fixed grease whip for the TO bearing. That's a great idea.
What kind of rear axle is that? It looks huge.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Thanks! The internal I used inside double panels. The black stuff came in a quart can. I used a undercoat gun with the nozzle set on a concentrated spot shot and got in the areas I knew the black wouldn't get.
BrandonMag
Dana 50 rebuilder
Oregon east
Upon closer inspection of the pic where the rear axle is visible, it looks like there's a lid from a plastic tote leaning up against it. I thought you had thrown a Dana 80 under it. LOL
laserjock
Almost there...
Okay, so it's more of a paint like the POR 15 type stuff only eastwoods flavor? That's what it looks like from the pictures.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Doors, fenders, inner fenders, and 2 hoods at sand blast. Also picked up a NOS tailgate from Mike Moore. Making progress... Slow progress.
Sent from my SM-G920V using Tapatalk
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Got all the metal back from blast. The hoods need work, doors are all good but one little hole that needs a patch, inner fenders and fenders are perfect. Got a hood coming to me from Oregon, picking up at nationals. Thinking these are good hoods for someone that's just using the truck on a farm, or isn't getting crazy with body work.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Cut the latch mount area out to swap and use the old style. That was not easy to cut perfect metal, but the plasma cutter made quick and easy work.
Even spot welded everywhere the old gate split.
lewisstevey7
