Power Steering Pulley
nine9six
Desmo Inside
Alachua, Florida
Greetings! I'm sorry if this has been discussed somewhere, but I've been searching for a while and haven't found a clear answer...
My father and I are replacing the Power Steering Pump on my '86 6.9, but the Pulley has to be replaced (long story). Does anyone know where I can find *just* the Pulley for sale?
After a good bit of Google-ing, I *think* the Part Number is: D8TZ3A733A
The Pulley has "D8TC-AA" stamped on it.
Any help would be SOO appreciated! :cheers:
Power steering pully remover installers are often loaned or rented from parts stores.
It is a common tool
Google...
Power steering pulley puller
Usually harbour freigjt has pullers...
Good luck...
Oh crap....ya stupid me...well likely need installer too
Tell us how mqny grooves and diameter and someone likely has one I have lots floating around
nine9six
Desmo Inside
Alachua, Florida
Wow! I wasn't expecting any replies this fast, let alone that many.
Yes we have a tool to remove the pulley, and we got it off of the pump. The first person to have a go at it (side-note, not me!) used one of those 3-prong type of tools. That obviously isn't what you're supposed to use. So here I am... ;)
The type I'm looking for is a "V"...if I'm saying that correctly? It's not a serpentine, and there are no other grooves where the belt goes. Those are all I can find on Google. The "V" kind is proving to be (for me, anyway) rather elusive.
*Edit*
I'll have to double-check the diameter when I go back over there in the morning.
jwalterus
Made in America
Garrison, ND
Check with a local alternator/starter rebuilding shop.
The local guy up here is the best source I've found to buy any v-belt pulley, since the company he gets his from makes them for all applications he just calls them and tells them what he needs.
Otherwise junkyard it.
i have a few for v-belt.
pm me with a diameter and an offer.
ironworker40
NYC Ironworker
nj
Go to a junkyard with your pulley in hand. That pulley may be used on more than trucks so look at cars also.
nine9six
Desmo Inside
Alachua, Florida
Thanks for the heads-up everyone. I've noted the diameter (5 3/4) and will begin my hunt tomorrow. Thanks again, and I hope everyone has a great New Year!
nine9six
Desmo Inside
Alachua, Florida
Thanks for that heads-up.
I knew that I read "5 7/8" on here somewhere, but I was told by two people (locally) that I was wrong. Small "victories"!
Sad to see plastic pulleys on our engines. Sorry guys.. I sure wont install a plastic pulley. I fear the plastic. I'm thinking many Ford or Mercurys run this same pulley. Might even be on the Lincoln line too.
Staff online
