tbirdfiend281
Ok, the truck is as follows, ats 093 kit that I put on, bought used locally, complete factory installed kit, 2.5" banks downpipe and a 2.5" straightpipe. 84 6.9 c6 4.10 truck, uses a little oil, no coolant, and generally runs well, fuel settings are stock as stock can be pump and injectors are in good working order to the point the truck has a light has a light haze near WOT at highway speed but that is really the only time you see anything out of the tailpipe at all.
Well friday my buddy and I where bored and began to install a boost gauge on the truck. I had the bright idea to tap the wastegate line for the boost signal. So I unhook the wastegaste line, run it away from the actuator and directly into the boost gauge, just to get a check and see if the signal is good and everything is fine. It does get a boost signal, but I am only seeing 6psi on the gauge. I figured with the wastegate actuator pressure line unhooked the wastegate shouldnt really actuate at all, and the boost would be in the 7-8psi range. Well after the quick run to get drinks, I try and move the wastegate and it seems to be locked up, would not move either direction. I think there may be an issue in there, I have to unhook the rod to determine if it is in the exhaust housing or in the wastegate actuator, but wanted to touch base here first to get all the correct information I may need before I go and do this, because if its an issue in the exhaust housing, I am going to have to pull the turbo off and work some magic.
So that being said, what do you guys think may be going on? Did these 093 kits have issues with the wastegates often? Is the wastegate super difficult to move with a pry bar or is there actually a problem?
FYI to keep this from being a redundant forum thread, I have a lot of experience working with turbos and diesels.
thanks people.
thanks people.
