defecater
Recently got done swapping out a bad E4OD for a T-19 behind a 7.3 in a 93 F-350. I sourced the transmission, bellhousing and flywheel from an 85-86 ish F-250 with the 6.9, and bought a new clutch kit from the local parts store. For the pedal assembly and hydraulics, I went to the local junkyard and pulled them from an 92-97year of truck with obviously a ZF 5 speed.
I did notice two things about the pedal assembly that I didnt like- the nylon bushings that the crossrod rides in were worn/unseated, and the side of the assembly that the master cylinder attaches to through the firewall had apparently been broken loose at some point and someone did a crappy job of welding it back together. I managed to scrounge up some steel tubing with just the right inside diameter, and permanently welded in some support sleeves to replace the bushings. Didnt do anything about the welds, as even though they look crappy, it appeared to be straight and has plenty of quantity to suffice for quality.
Anyway, my problem is that the clutch will not disengage entirely. Is it possible that I have some sort of mismatch in the parts that are keeping this from happening?? I could be totally wrong on this, but it seems to me from my past experiences with Ford hydraulic clutch setups, that the external end of the fork looks like it is too far back, plus, when I installed the slave cylinder it popped easily into place, whereas all others I have done that I can recall were real mothers to get the rod pushed in and the slave seated in the bellhousing bracket.
Or is there something else I am overlooking???
