PLEASE HELP DT466E
corliss010492
mass
i have a 98 international with a dt466e.
PROBLEM 1
when i try to start the truck it will start and run for a couple seconds and then stall(oil pressure gauge doesnt move) then when you try to start it back up it will crank for a few seconds and build oil pressure and start up and run. cracked oil pick up tube? i have codes PID 164 FMI 1 FLASH CODE 335 PID 164 FMI 4 FLASH CODE 124 PID 100 FMI 1 FLASH CODE 313. could be more than one issue maybe?
PROBLEM 2
i did an injector buzz test on the truck and came up with code SID 3 FMI 3 FLASH CODE 423. it has a new cylinder 3 injector, bad valve cover wiring harness? truck seems to have a skip win running and doesnt have much power.
Please help, any help is appreciated
