Nope.. The amount cut off the heads can't be more than 10 thousands. They are oem at 4.805 to 4.795 measured off the machined head surface and the valve cover gasket area. The block must be measuring from the top of the deck to the center of the crank 11.137 to 11.141. So only 4 thousands can come off the block deck and still be in oem specs. This measurement finding the center of the crank to the top of the block is a tuff measurement to get. I'm really good with depth mics but I can't do it without a special dummy shaft in the crank webs. Even then you can only measure to the top of the round shaft. Then add half that thickness to find your true measurement.
