idi_econoline
No Bed For Me!
Need to visit y'all more often than just when I have a problem.... <hangs head>
OK. Fuel leaking, mostly during short morning freeway runs. Went to my buddy's place last weekend - about 50 miles - with almost no leaks, as I ran only 35-45 the whole way, off-freeway.
Then, put in ear plugs and ran her without the inside doghouse cover! After 55-60 in the morning on a connector ramp, 3rd gear, saw a heavy fuel flow down the valley pan, so deep that I could see ripples in it!
Weep hole sooty-dirty, so no fuel gush from there. Nothing coming down from upper side of things.
Friend hydro_idi suggested the olive was bad. Except the olive came with the Conestoga flexible fuel line like 3-4? years ago. Checked tightness of the fitting into IP. Was able to tighten it ½ turn. WHEW! That fixed it, thought I.
Nope. Getting gradually worse! Using a plastic tray UNDERNEATH when parking in friend's driveways.
So, do pull IP and lines to look for a cracked lower injection line? Kinda lost here. TIA.
Thoughts, kind sirs??????
PS: DON'T TRY THIS AT HOME, KIDS!!!!!!!
