firehawk
Long, fun weekend of racing, but my truck now has a new problem: overheating. It seems to be rpm dependent, as even as a fairly low speed, it will run hotter with a lower gear. Also, a/c on or off makes little difference, and pulling or not a load makes little difference. Coasting down a hill in neutral cooled it off a good bit, but running level at 60 or higher would see very high temps.
I was too tired to take temp readings of various parts plus it cools down fairly quickly at idle.
For reference, the truck did not loose coolant and I have a new radiator of oem design and the engine is all stock. Stat and water pump were replaced about 4 years ago, but not by me, and I don't know what they used, but I am fairly certain the stat was not right as it takes too long to warm up.
My first guess is either stat, collapsing hose, or water pump, but I would love to hear some suggestions.
