Whoops, sorry man. Figured one cooling system was like the next.. My bad
Our cooling system does function the same as most any Ive ever dealt with. with the t-stat closed coolant flows through the bypass circulating coolant within the block creating a more average temperature throughout the engine. as the t-stat opens it gradually restricts the bypass hole, though never blocking it completely, making the coolant want to flow to the radiator. With no stat the coolant will still flow to the radiator, as it is much easier for the volume of coolant to flow through the radiator than that little bypass hole. many cooling systems function excactly this way, most all have a bypass of some sort, but not all block it as the t-stat opens
the correct t-stat is important because it flows enough to make the coolant want to flow through the radiator and not just the bypass. the generic t-stat doesnt flow as much, and doesnt restrict the bypass. this lets more flow through the bypass than should, and less flow through the radiator than should be flowing.
