So a 460 would be the 5.72? This kind of makes it a "rare" transmission.... ugh. What's the modifacations to bolt it to a 6.9?
-Jon
Yes, the 460 ZF5 has the 5.72 1st and the 5.24 reverse. Check out
THIS POST about converting a 460 ZF5 to diesel.
I just did these modifications to my 460 ZF5 this past weekend. I used a small drill press to do the mods as I know I'm not that good with keeping a bit perpendicular.
The top two holes are in the same location, but need to be enlarged to 1/2 inch. I used a plain 1/2 bit for those. I then bolted the IDI tranny adaptor plate to the ZF5 and used it as a template.
Three of the four remaining bolt holes overlap the 460's bolt holes. I knew these where going to be tricky to drill with a plain bit. I used a 1/2 inch 4 fluted end mill to drill those holes. Otherwise, a plain drill bit would want to walk/drift toward the preexisting 460 bolt holes.
One of the four remaining bolt holes doesn't overlap the 460 bolt holes. So, I just used a 1/2 transfer punch to make a notch in the center (again using the adaptor as the template) and a plain 1/2 bit to drill that hole.
Then I used a 3/8 transfer punch for the dowel holes and a 3/8 plain bit for those as well.
I have a bunch of photos of the process, I just haven't had time to load and post them yet.
Heath
