ifrythings
Makes sense. Better airbags have lifetime warranty though. Plus being able to adjust it much easier to suit the RV weight is handy. Sometimes its heavier behind the axle if the grey tank has water in it.
The helper springs run about $100 more for a set plus mounting kit. Probably is the bettter option.
There are 3500lb (3510) and 2500lb (9510) versions, not much different in price. Not sure which would be better. Too much help wouldn't be good either.
Plus the 3" leaf mounting hardware kit:
The spring shops around my area won’t sell those add on springs like that, they say they put too much stress on the main leaf causing them to break. My sister bought a f150 that had something like that on it and the springs were all broken, hence how I found out. Personally I wouldn’t run it, there’s a couple spring outfits that have great prices, I haven’t used them as shipping to Canada would be brutal.
https://www.sdtrucksprings.com/leaf...MIyuLarYno5gIV0Rx9Ch1UhAUGEAAYASAAEgJMSfD_BwE
https://www.autoandtrucksprings.com/
